Release Highlights
v2022.4.0 - November 23rd, 2022
- Specify a color and/or symbol for each marker in select one from map
- New blank form sort mode: "Last Saved First" sorts by time of last filled form save
- Explicit crash screen when Collect launches after experiencing a problem
- Detailed release notes: https://github.com/getodk/collect/releases/tag/v2022.4.0
v2022.4.1 - December 8th, 2022
- Ignore choices with invalid geometry in select one from map
- Prevent most common restore crashes
- Detailed release notes: https://github.com/getodk/collect/releases/tag/v2022.4.1
v2022.4.2 - December 19th, 2022
- Replace the
selfiewidget implementation to fix multiple crashes - Detailed release notes: https://github.com/getodk/collect/releases/tag/v2022.4.2
- Replace the
v2022.4.3 - January 25th, 2022
- Add "Updated at" subtext for forms that get updated attachments
- Detailed release notes: https://github.com/getodk/collect/releases/tag/v2022.4.3
v2022.4.4 - December 27th, 2022
- Fix crash when updating form
- Detailed release notes: https://github.com/getodk/collect/releases/tag/v2022.4.4
Download release
- https://play.google.com/store/apps/details?id=org.odk.collect.android (recommended)
- ODK-Collect-v2022.4.4.apk
Report issues
