Collect will stop connecting to Google Drive/Sheets in Fall 2023
In Fall 2023, we will remove Google Drive/Sheets functionality from ODK Collect. Users will no longer be able to download blank forms directly from Google Drive or send completed forms directly to Google Sheets. We are making this change to enable us to move faster on features that serve more users.
We believe most people use Google Drive/Sheets because they see it as reducing the financial and technical cost for organizations to use ODK. But because Google Drive/Sheets were not designed to be a replacement for an ODK server, the user experience is not intuitive or reliable. We know that projects using Google Drive/Sheets are unable to use ODK to its full potential and we believe they will be best served by using a server designed for use with Collect.
In the last 12 months, Google Drive/Sheets was used for 6.1% of submissions sent from Collect. Roughly 5.2% of our user base used it. We believe that with sufficient warning, these users will be able to migrate to ODK Cloud, self-host Central, or use an ODK-compatible server.
If you use Collect to connect to Google Drive/Sheets, we recommend the following actions:
  • Plan for future data collection efforts to use an ODK server
  • Stop all automatic updates of Collect for devices connecting to Google Drive/Sheets
  • Use Collect projects if you need to start new initiatives while data collection is still being done using Google Drive/Sheets
  • Once all Google Drive/Sheets data collection is complete, resume Collect automatic updates
Stopping automatic updates will allow you to continue using Google Drive/Sheets for as long as you need it (or until Google changes something on their end). You will also be able to install Collect v2022.4.2 with Google Drive/Sheets support manually from APK.
:warning: We generally do not recommend stopping auto updates or using older versions of Collect. However, in this case, we think it provides the smoothest transition out of Google Drive/Sheets.
To stop automatic updates of Collect:
Changes to Collect will be staged as follows:
  1. In Collect v2023.1 (~March 2023), there will be a banner at the top of the main menu for users of Google Drive/Sheets. It will tell them that Google Drive/Sheets support is going away and will link to this post.
  2. In Collect v2023.2 (~summer 2023), users will not be able to configure new projects that connect to Google Drive/Sheets.
  3. In Collect v2023.3, all user-visible Google Drive/Sheets functionality will be removed.
We welcome feedback you may have on this approach. Are there implications we may not have considered? Do you have alternate suggestions on how we make this change as seamless as possible for users?
Updates to this original post
  • Feb 28, 2024. An upcoming Google policy change means old versions of Collect will stop being able to connect to Google Drive/Sheets. See this for more.
Thank you for the update. My team belongs to that 6% who have been using Google sheets to log our data. Could you please clarify if Google will continue allowing data collection from the ODK application?
It's unlikely that Google will explicitly ban Collect. What is more likely is that Google will change or sunset the Drive or Sheets APIs that Collect relies on. We do not know if or when that will happen.
What a pity they don't want to work with GoogleSheets anymore. The only reason why we started our project in ODK was the possibility of managing the database that was generated with the forms easily for any user. Filling the information, correcting errors, deleting poorly saved records, with all the simplicity of a Google spreadsheet.
Do you know for sure the exact date on which you will stop providing this service? I firmly believe that it is a bad decision (even if we are only the 6% of users). Something that differentiates you from the rest of the forms services is the possibility of using GoogleSheets. Remember that it is an extremely simple and free option. Most users do not know how to install a server or we can not afford ODK Cloud prices (it does not have a free version). Hopefully at some point they can resume this service so characteristic and original that they had with Google.
I hope so!
If you stop updates to ODK Collect, you should be able to continue using v2022.4.2 for some time, quite likely years. The only thing that would change that is if the Google Drive service changes.
We're glad to hear that you've found value in connecting to Google Drive/Sheets and again, you should see no changes if you freeze the ODK Collect version and continue with your existing usage.
Dear @LN . Thaks for your reply. I will do it.
Really sad to hear that. Almost 3 years running forms this way and then generating a final repost in PDF with scripts directly inside the google sheet and now this is threatened.
I agree with Nicolas, this is a really bad idea and this features is what differentiates you from the rest of the form services.
@gmiranda I understand this change is frustrating, but please understand that Collect is made by two people who are providing free software to millions of users. For us to keep ODK going, we need to make thoughtful choices about how we use our limited resources.
In this particular case, we are not taking anything away from you. In fact, we've gone out of our way to ensure you can freeze the ODK Collect version and continue with your existing usage. Is there any reason why this wouldn't work for you?
As I said, it seems the alway it works todays is threatened. Any modifications on Google side and I understood we will have no support anymore.
For the project I have running, nothing to do right now. Just hope it lasts for long time.
But I wouldn't rely on this for any new project/form from now on.
Over the past few years, Google has made policy changes that limited how apps can integrate with Drive/Sheets with the goal of improving user safety and security. We were hopeful a change wouldn’t affect the Google Drive/Sheets integration immediately but the risk of something like this happening was one of the reasons why we opted to deprecate the integration a year ago.
On February 21st, we received a notice from Google with a policy change affecting the usage of Google Drive/Sheets in older versions of ODK Collect. Collect will require a review to ensure it meets new policy requirements.
What’s happening now?
We have until May 21st (90 days) to pass this review. Our goal is to pass the review, but it is unlikely because as far as we understand, Google no longer allows the methods Collect used to access Google Drive/Sheets folders. If we fail review, old versions of Collect will stop being able to connect to Google Drive.
What do you need to do?
If you are still counting on older versions of Collect to connect to Google Drive/Sheets, we recommend starting to plan for an alternative now. If this review fails, the only way to get Google Drive/Sheets functionality will be to fork an old Collect version, use your own pre-release OAuth token that does not require review (limited to 100 users), and distribute your own Collect APKs.
We will share updates as soon as we get them.
We have received an extension from Google to delay the new policy requirements for old versions of ODK Collect for 80 days from today. On July 23, 2024, old versions of Collect will stop being able to connect to Google Drive.
Dear ODK team, thank you so much for your hard work on ODK.
I got to know ODK around 2017, when I was traveling around the world by bicycle. At the time I wanted to track my progress and various data while traveling. Every day I would fill a form to respond to questions such as: did I cycle today or was it a rest day? Did I pay to spend the night or not? How much? Where did I sleep (wild camping, official camping, hotel, b&b, hosted by someone etc)? How many km did I cycle? And a notes field to write down some memories.
All this data would then be collected in a google drive spreadsheet to be able to extract all sorts of information. I enjoy coding and I enjoyed learning XLSForm to build my own forms.
I could have probably used another platform (such as google forms), but being able to use ODK Collect offline was key, because camping in the tent in remote places of the world I often didn't have an internet connection for days in a row. With ODK Collect I could still fill the form daily and then upload them all together when I had a connection.
As you can see my ODK use case is very personal, not of a professional, it's more of a hobby, and I can't definitely sustain the expense of ODK Cloud.
I understand the removal of the Google Spreadsheet integration, I'm currently using an old version of the APK and it still works, but when it won't work anymore, what can I do to keep using my forms?
Thanks a lot
Daniele
@sneike When Google Sheets stops working, you can either self-host Central or try Ona or Kobo.
  • Self-hosting requires technical expertise, but will offer you all ODK features at a low cost (~$6/month on DigitalOcean). It won't be as fast, reliable, or supported as ODK Cloud, but it sounds like you don't need that.
  • Ona and Kobo offer varying levels of ODK compatibility. If you are used to Google Sheets and don't collect a lot of data, one of their no-cost plans would likely work for you.
Whatever you choose, I'd encourage you to make the change as soon as possible so your data is not trapped when Google Sheets stops working.
Hi @yanokwa thanks for your quick reply. I've been playing around with Kobo and it seems to work for me. Thanks for pointing it out. I feel bad moving away from the ODK platform, but it is necessary for my use case. Thanks again for your hard work.
