ODK Collect betas are an opportunity to get community feedback on upcoming releases. If you have an ongoing data collection campaign, we recommend quickly verifying your form on a test device. The release will be delayed until all reported issues are fixed.
Joining the beta program
Leaving the beta program
You can leave the beta program from the bottom of the Play Store at any time. Once you leave, you will get the next production update when it is released. If you need to go back to the previous production release, uninstall and reinstall the app. Your settings will be reset but your forms will remain (though backups are always recommended).
What to check in this release
- Submissions are sent as UTF-8 (this may affect those who don't use ODK Central)
- Default Android splash screen. Custom splash screens have been removed as announced here
- Target Android 12. This could lead to unexpected behavior changes. Please report anything suspicious
Additional testing
You can find a full list of changes in the release notes:
Thanks to all testers for your help!
