This release is currently planned for mid-December. It will make the bottom sheet for select one from map more user friendly, prevent self-intersecting geoshapes and geotraces, and make a number of smaller improvements. Check back for updated betas as we get closer to release.
Why we do betas
ODK Collect betas are an opportunity to get community feedback on upcoming releases. If you have an ongoing data collection campaign, we recommend quickly verifying your form on a test device. We will keep sharing new betas as we respond to your feedback and will let you know when the beta is a release candidate.
Joining the beta program
Leaving the beta program
You can leave the beta program from the bottom of the Play Store listing at any time. Once you leave, you will get the next production update when it is released. If you need to go back to the previous production release, uninstall and reinstall the app. Please make sure to back up or submit any important data.
What to check in this release
Updated repeat dialog to increase clarity. Learn more.
intersects function to detect self-intersections in geotrace or geoshape values. Try it with this sample form.
Guidance hints are now displayed and collapsed by default. Previously, guidance hints were not shown by default. They are now shown collapsed unless explicitly configured to be turned off or always shown.
Updated style for markup and signature exit dialog. The functionality should still be clear to existing users.
Mapbox mapping library upgrade. If you rely on Mapbox you may want to double check this.
Additional testing
You can find a full list of changes in the release notes:
@LN - I just found out that I can't tap to select a geopoint or a geoshape in Mapbox in the beta. Assume same goes for geotrace. Google basemap allows selection.
We’ve added the intersects function, which detects self-intersections in geotrace and geoshape values. This is our first step toward preventing invalid polygons, which we discussed on the Insiders call last month. You can now try the function out using this sample form, see how it behaves, and share your feedback as we continue shaping the feature.
Other improvements
System Entity properties (__version) and styling properties are now hidden in the select one from map bottom sheet
Does anyone have feedback on the new repeat dialog?
If you’ve tried the beta, you’ll notice we’ve updated the language, added icons, and stacked the buttons (so that it works better on smaller devices with longer translations). Let us know what you think!
@Tyler_Depke reminded me about this. I didn't think that a Collect beta offered this feature yet as I haven't seen it mentioned in the Beta announcements or the thread about entities from repeats, but did I miss it? Looking at the beta release notes, is this it?
