Create and update Entities from repeats
Developers may be interested in the companion ODK XForms spec proposal.
:warning: Updated proposal below!
Background
Repeats make it possible to capture data about multiple things of the same kind within the context of a single form. This means capturing the item data can be embedded in a broader flow and there can be logic used to perform validation between those items.
Users want to create Entities from those repeat so that they can follow up with them. Some practical examples:
  • In an agricultural context, it's common to have to capture information about many fields in the same farm. See @dast's Insiders lightning talk and showcase post.
  • Household surveys often involve capturing info about individual household members associated with that household. See Form linking
Currently, a single form submission can only create or update a single Entity. We propose making it possible for a submission to either create or update a single Entity OR create/update multiple Entities in a single Entity List from a repeat.
XLSForm spec
entities sheet:
We propose adding a repeat column in which a reference to a repeat can be specified. All other references used in other columns such as label, create_if, entity_id, etc, would be evaluated in the context of that repeat.
For now, exactly one Entity declaration would be allowed.
list_name repeat label
trees ${tree} ${species}
survey sheet:
When an Entity declaration is specified on the entities sheet, save_to values would only be allowed in that repeat.
type name label save_to
begin_repeat tree Tree
geopoint location Get tree location geometry
text species Species species
end_repeat
Future work
In the future, we expect to further expand to the following:
  • create/update multiple Entities in a single Entity List from a repeat AND a parent Entity in the same or a different Entity List
  • create/update multiple different Entities from the top level and from multiple repeats
Please let us know if you have any feedback!
Absolutely in support of this — great initiative!
This would be a great step forward. Do I understand correctly that this is not yet implemented and that only one entity from one repeat could be populated with data from the submission?
To bridge the gap until this feature is properly implemented in ODK we have developed a script for pyodk to retrieve selected data from repeats of a given form, save it in a csv which then is uploaded to Central to populate the form the next time the dataset is used. Would that be worth to share in a showcase?
You can also do this with QuODK - you can load the submission data (repeats) into QGIS then use that as the layer to create (or update) an entity list (exported as a CSV). Followed by a pyODK script to talk to Central.
So certainly not as simple as your tool, but there is the opportunity to adjust any geometry [or any other attributes] if needed, so it has some 'strength'. You can also be selective as to which attributes to include in the entity list.
I'd like to say that I'd thought of this specific use case when designing QuODK, but I confess that I only realised it was applicable when I read your post. :slight_smile:
I would find that useful - any 'grown up' scripts for pyODK would be really useful. My kindergarten scripts are a little wobbly so I find examples a good way to learn.
Hi @LN,
Exciting developments! A small clarification for implementation with this future spec, how would properties shared across all repeat entities be managed? For example, in a household survey you might first interview the household head, then enumerate household members in a repeat. If I want to register the household’s village (selected, say, from a predefined list in the main body of the XLSForm) as a property of the entity shared between all entities for this submission, will it be possible to save_to outside the repeat? Or do I understand correctly that instead I will have create a calculated field inside the repeat that retrieves this value, so it can be stored with save_to?
I still have to test your tool. So many things going on at same time :collision:
I’m not quite sure if our script really is grown up. AI was helping a lot. But yeah, it seems to work.
On the assumption that Collect beta functionality exists for entities from repeats, I made a quick test form in a similar manner to @LN's example at the top to see what would happen, for now only with save_to against fields in one repeat as also creating entities outside a repeat is incomplete. Using Central 2025.3.1
Spec is still at 2024.1.0 so I guess this thread is the spec discussion for 2025.1 in the current Collect beta?
I modified an existing demo entity form to put a repeat around the fields and added the repeat column to the entities sheet and found;
  • Enketo - allows the first repeat. In the second, third etc repeats the top note shows a read only text field under it and then the following question has no selections visible and the questions after that are not shown at all. :cross_mark:
  • WF - allows >1 values in the repeat, can create/update ok. :white_check_mark:
  • Collect 2025.4.0 beta 2 with experimental entities spec 2025.1 off: form doesn't load
  • Collect 2025.4.0 beta 2 with experimental entities spec 2025.1 on: can create/update multiple entities ok :white_check_mark:
@Tyler_Depke - looks like we can start testing repeat entities workflows :smiley:
I spotted this in the docs, saving the entity ID in the submission that creates/updates it via this as a calculate:
/data/meta/entity/@id
This didn't work as is for entities from repeats, I expect I need to include the repeat name somewhere in the XPath, looking at a submission XML I can see <meta> and @id under the repeat and this works:
/data/your_repeat_name/meta/entity/@id
Will groups affect this for some future implementation where a single submission can create entities from repeats plus outside the repeat, either inside or outside a group that would need to identify where the meta block exists? Currently the group in my repeat is at the same level as the meta block.
Finally managed to test this new feature.
All worked as expected and described in the specs by @LN , although I didn’t test yet create_if and update_if. :slightly_smiling_face:
But yes, It only works with the Beta version of Collect with experimental entities spec 2025.1 on. Thanks to @ahblake. I would not have found this in the Project settings –> Experimental.
But this feature will only reveal its true power once the following are possible at the same time:
  • Entities of the parent area
  • Entities of one or more repeat groups
We continue with imperfect work-arounds until then.
Thank you so much @ahblake :folded_hands: I also wanted to play with repeat entities and I initially missed the experimental entities spec. Your detailed post was super helpful (as usual) in helping me through how to use it.
Thanks for tying all the pieces together, @ahblake! Great to see how much enthusiasm there is for this functionality.
Yes, exactly. This means you have more fields in your submission that you don't really need but it makes the relationship between form fields and Entity properties easier to see in form design.
I would recommend using a relative expression. For example, if you have a calculate directly in the repeat (at the same level as the meta block as you said it) that needs to access the Entity system ID, the expression ../meta/entity/@id should work. That way you don't need to think about nesting outside the repeat, only inside. Could you please tell us how you're using the system ID? Is it to create links between Entities?
Here's an overview of the status:
  • pyxform as released in Central v2025.3+ can generate forms following the 2025.1.0 Entities spec as outlined in the top post, but only for a single declaration per form, either at the top level or in a first-level repeat (not in nested repeats)
  • Central v2025.3+ can use the new spec
  • Collect v2025.4 is still in beta, it can use the new spec when opted into in settings. In the next beta, it will create Entities from repeats offline, still requiring opt-in.
  • Enketo can't use the new spec because of this issue which we don't currently have plans to fix. Those who need web-based forms for Entities with repeats will be able to use Web Forms.
Here is a simple form to create multiple Entities in the trees list: [https://docs.google.com/spreadsheets/d/1bHnF-1W39P2uNrE3Od8BIh7DtF4ErB-sK4T4flPEJkw/edit?usp=sharing](Entities in repeats)
We initially thought we would start by releasing what we have now: limited pyxform support and Central support with opt-in support in Collect. However, as we've created more test forms and explored the problem space more, we would like to have a clearer path to having performant links between Entities before we release.
As @dast says, almost every context in which it's helpful to create or update Entities in a repeat also involves a parent Entity (and possibly grandparent!). Currently, form designers are entirely responsible for making sure they establish the links they need. Because the system has no knowledge of those links, looking up the children from the parent is not performant (as @dast and @ahblake have pointed out in other threads).
Changing the way those links are represented after they've been created would be a time-consuming operation for each data collector. So we're doing some design work now to see how we can do this thoughtfully.
One additional point that has kept us from releasing as things are is that as we write test forms, it "feels like" the links between Entities should be created implicitly based on the shape of the form and so it's easy to forget to define them.
We're working hard to get this right, thanks for all your input so far! For those of you who have tried the functionality, please consider sharing your test forms and the projected sizes of your biggest Entity Lists.
If you link Entities already or are planning to, it would also be helpful to learn about relationships you want to represent that are not simple parent-child ones. For example, if you want to represent links to multiple parents, that would be helpful to know. That would be something like having participants that you want to be able to access from households, schools, and districts lists. In that case, participants can be said to have three parents.
CC @laurespake from ODK Collect v2025.4 Beta: guidance hints shown by default, updated repeat dialog - #10 by laurespake; it would be great to know more about whether you need any linking between Entities and if so how you plan to represent it.
:person_facepalming: duh! Of course.
My thinking right now is that i want to include the id of the entity (especially in the create case) with the submission so that any report includes the entity it refers to uniquely, so rather than "finding #1 at this time on this report" which could then be finding #17 at a subsequent submission, it also includes/uses the entity id.
Likewise the entity might have a field for which submission created it, or a join of every submission that has touched it - but these values are likely better retrieved from the entity audit trail
It's not so obvious! We're going to need to provide some really solid examples for this.
Yes, that makes a lot of sense. We know linking submissions to registration/creation forms is a painpoint and one thing we're planning to do soon is to include the created Entity in the data exports (Github issue). We will likely do the same with repeat instances though perhaps in a later release.
This is also something we plan to eventually provide directly from Central but we don't have a timeline for it currently.
We have just published a new Collect beta with offline support for Entity creation and update. You can find out more and see some sample forms in the beta release announcement.
We have now updated the XLSForm model based on feedback to simplify the entities sheet and to make it clearer on the survey sheet which save_to belongs to which Entity. Our current plan is for XLSForm to allow any number of rows on the entities sheet as long as the list_name column value is unique across them. In other words, a submission will be able to create or update many Entities and the only way to write to multiple Entities in the same list will be to use a repeat.
This means we will remove the undocumented repeat column from the entities sheet. @Lindsay_Stevens_Au is working on the pyxform implementation and we are hoping it will be available with or shortly after the Collect v2026.1.0 release.
Updated spec
The entities sheet MAY include multiple Entity declaration rows, provided that no two rows reference the same list_name.
If the entities sheet has more than one Entity declaration, then each save_to value on the survey sheet MUST be prefixed with a list_name followed by #, where the prefix matches a list_name in the entities sheet.
Example:
households#hhid
participants#first_name
The portion after # is the Entity property name. It is not valid to have save_tos with different list prefixes directly in the same group or repeat. See more in the XForms spec and the pyxform issue.
Sample form
entities sheet for a form that creates Entities in the households and participants lists:
list_name label
households ${hhid}
participants concat(${first_name}, " ", ${last_name}, "(", ${hhid}, ")")
survey sheet:
type name label save_to calculation
text hhid Household ID households#hhid
geopoint hh_location Household location households#geometry
begin_repeat member Member
text first_name Member first name participants#first_name
text last_name Member last name participants#last_name
calculate member_hh participants#hhid ${hhid}
calculate hh_link participants#hh ../../meta/entity/@id
calculate member_id ../meta/entity/@id
end_repeat member
For now, we have decided not to do any automatic relationship discovery. We are starting design work on a way to state from Central that certain properties represent links between Entities and will share those proposals shortly. This will be important for performance.
We also intend to provide a way from XLSForm to more easily reference an Entity's id, likely something like <list name>#__id (households#__id) instead of ../meta/entity/@id which will be even harder to write since pyxform will decide where to put the meta/entity block.
all my christmases have come at once.
this all looks very straightforward, which is a testament to the design work you have done.
I am going to create some test forms so I'll be ready to hit the ground running!
@LN I hope I've done something dumb here, but webforms seems to have a bug with the UUID assigned to the repeat items vs the UUID in the entity list for those after the first one.
I have a form with a group in a repeat, and a field to grab the entity UUID calculated as ../meta/entity/@id
I submitted through Webforms (tested twice, same issue), then compared the submission 'grab entity UUID' field values to those in the entity list and repeat 1 matched, but 2 & 3 didn't.
eg: (position order same for all, 1 to 3)
submission had this:
311a0481-77e2-440e-95a9-c2a4cd3f0e12
aee39ca6-4ded-470b-a762-cec1e6e22ba0
db0d4f36-9259-42e2-96ae-a88784342c5b
entity list had this:
e7c3c173-863c-4038-9652-19b5b00fd93c
4100e7c1-5210-4869-ab70-75bb547d6b60
Compared with submitting via Collect (2026.1.0b3), all matched.
e393660b-52a6-4fba-8397-bc5cefe99a86
c3c9c1d2-9069-43de-817a-c978e600ef48
4334bc72-9b90-4731-b283-b7720a989dfe
The entity_id on the entities sheet was defined essentially as; if create = uuid() if update = name value of relevant entity, but these cases were all creates.
This same issue is related when trying to edit via WebForms - I get an error that all entities except the first have mismatched UUIDs so no entities get processed. Editing via Collect works with no problems.
eg - 4x existing entities, attempt to edit, submit and check 'more' for the submission:
Failed to process 4 entities in submission due to 3 errors: (Entity 2) The entity with UUID (610f4878-1d30-460d-97a6-e98027c85d9a) specified in the submission does not exist in the dataset (G). (Entity 3) The entity with UUID (f1f25964-0e10-4757-a23a-ba8ff5ddc573) specified in the submission does not exist in the dataset (G). (Entity 4) The entity with UUID (d099f43c-bf7f-40bb-9317-2718a66a5cf8) specified in the submission does not exist in the dataset (G).
This is very surprising indeed! We recently identified some issues in Web Forms with events like odk-instance-first-load and odk-new-repeat firing too often but as far as I know all fixes for those known issues have been released. Also a change caused by a setvalue action should update dependent calculates.
We are investigating and will update when we know more.
I’m having a look at that Web Forms issue… @LN put together this form, which triggers a similar bug, but it’s not entirely the same as what you’re reporting
<?xml version="1.0"?>
<h:html xmlns="http://www.w3.org/2002/xforms" xmlns:entities="http://www.opendatakit.org/xforms/entities" xmlns:ev="http://www.w3.org/2001/xml-events" xmlns:h="http://www.w3.org/1999/xhtml" xmlns:jr="http://openrosa.org/javarosa" xmlns:odk="http://www.opendatakit.org/xforms" xmlns:orx="http://openrosa.org/xforms" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
	<h:head>
		<h:title>participants</h:title>
		<model entities:entities-version="2025.1.0" odk:xforms-version="1.0.0">
			<instance>
				<data id="participants">
					<hhid/>
					<hh_location/>
					<member jr:template="">
						<first_name/>
						<last_name/>
						<member_id/>
						<member_hh/>
						<hh_link/>
						<meta>
							<entity create="1" dataset="participants" id="">
								<label/>
							</entity>
						</meta>
					</member>
					<member>
						<first_name/>
						<last_name/>
						<member_id/>
						<member_hh/>
						<hh_link/>
						<meta>
								<label/>
							</entity>
						</meta>
					</member>
					<meta>
						<instanceID/>
						<entity create="1" dataset="household" id="">
							<label/>
						</entity>
					</meta>
				</data>
			</instance>
			<bind nodeset="/data/hhid" type="string"/>
			<bind nodeset="/data/hh_location" type="geopoint"/>
			<bind entities:saveto="first_name" nodeset="/data/member/first_name" type="string"/>
			<bind entities:saveto="last_name" nodeset="/data/member/last_name" type="string"/>
			<bind nodeset="/data/member/member_id" type="string" calculate="../meta/entity/@id"/>
			<bind calculate=" /data/hhid " entities:saveto="hhid" nodeset="/data/member/member_hh" type="string"/>
			<bind calculate="../../meta/entity/@id" entities:saveto="hh" nodeset="/data/member/hh_link" type="string"/>
			<bind nodeset="/data/member/meta/entity/@id" readonly="true()" type="string"/>
			<setvalue event="odk-instance-first-load" ref="/data/member/meta/entity/@id" value="uuid()"/>
			<bind calculate="concat( ../../../first_name , &quot; &quot;,  ../../../last_name , &quot;(&quot;,  /data/hhid , &quot;)&quot;)" nodeset="/data/member/meta/entity/label" readonly="true()" type="string"/>
			<bind jr:preload="uid" nodeset="/data/meta/instanceID" readonly="true()" type="string"/>
			<bind nodeset="/data/meta/entity/@id" readonly="true()" type="string"/>
			<setvalue event="odk-instance-first-load" ref="/data/meta/entity/@id" value="uuid()"/>
			<bind calculate="/data/hhid" nodeset="/data/meta/entity/label" readonly="true()" type="string"/>
		</model>
	</h:head>
	<h:body>
		<input ref="/data/hhid">
			<label>Household ID</label>
		</input>
		<input ref="/data/hh_location">
			<label>Household location</label>
		</input>
		<group ref="/data/member">
			<label>Member</label>
			<repeat nodeset="/data/member">
				<input ref="/data/member/first_name">
					<label>Member first name</label>
				</input>
				<input ref="/data/member/last_name">
					<label>Member last name</label>
				</input>
				<setvalue event="odk-new-repeat" ref="/data/member/meta/entity/@id" value="uuid()"/>
			</repeat>
		</group>
	</h:body>
</h:html>
Is that similar to the form you’re using? Would you mind sharing your form (or a simplified version) so I can reproduce the issue you’re seeing?
Hi Gareth, I'll try to prune down the form to the minimum that causes the issue and share it.
@gareth @LN
I removed the before/after and while it still works in Collect and shows the error in WF (The entity with UUID (x) specified in the submission does not exist in the dataset for entity 2 to n), it is also behaving slightly differently to the original form.
I added some testing notes and tried to generate the UUID in the repeat vs the entities sheet as well to try to see what was going on, but I'm more confused now.
It really feels like a silly off by one error, but then I'd expect the same problem in Collect, or my entity items to update offset .
  • the calculate for ../meta/entity/@id is now blank for create or update in collect and web forms, I tried adding a trigger to it and putting it inside a concat, but it's just blank!
  • I replaced the entity_id expression with a field in the repeat that either grabbed the entity id else used uuid() and the errors persisted with Webforms and still worked fine in Collect, BUT when comparing the values in the submission vs the entity UUID:
    • when created in web forms, so all new UUIDs, the values in the submission matched the values in the entity list for repeat elements 1 & 2, not 3. Trying again, it matched for 1-9 but not #10.
    • when created in Collect, the values in the submission do not match the values in the entity list for any repeat element - almost as if Collect ignores the entity_id field for the create case. (the template does say that entity_id is for "The id of the entity that should be updated by filling this form" ?)
    • When updating, the submission values match those in the entity list for WF & Collect.
webforms entity UUID issue.xlsx (97.6 KB)
