Adding small photo with each answer
I want to add a small phot to each answer like the question attached here
Tablet
Show me how to add the photo and show an example for that please
I tried the media option but didn't work
If you are using XLSForm, you can add a media::image column and put the name of the media file (e.g., facemask.jpg). This works for question text and for choices. For the choice, you'll need to add the media::image column to the choices sheet.
Then you have to upload the media files into ODK Aggregate for download or put the media files that you want to include in the /odk/forms/formname-media folder on your phone.
I found this information at http://xlsform.org/#media and there is a sample form there that you can try.
Thanks a lot for your reply, I tried it but it doesn't work well..
I have attached a picture for what I get in the tablet
Is there any way to solve this
Abrar
It's going to be hard to help without seeing your form. Build a small one question form with just the question 29 and upload it.
Also, please describe how you are getting the media from your computer to the device.
example.xlsx (9.0 KB)
Thanks a lot, I have attached the excel form ..
Regarding the media, I just login my odk account and upload it from the computer ..
also have a probelm in that because in the odk account it only allow me to uplode one photo and i have two for this question
The form you attached is not a valid XLSForm. Did you confirm that the form worked before uploading it? If so, how did you confirm?
Can you also please include the Surgical.jpg and N95.jpg you are hoping to use?
Yes this is excel, I converted that using to XLSForm by the softwrae for that and no probelm.
The pictures I need are attached N95
The form you attached is not a valid XLSForm (download here) is not a valid XLSForm.
If I try to convert it to XML, it says "The survey sheet is either empty or missing important column headers." You can confirm by trying http://opendatakit.org/xiframe.
What software did you use to convert it?
When testing this I had issues with media displaying correctly when there are language options in the survey if the media column(s) are not also localized. If you remove the ::English you should be fine. Or you can add a media column for each language. See below. This XLSForm documentation says "::[language] is optional" for media::image::language but it seems like that may not be be always the case, depending on other aspects of your form.
survey tab
|         type         |   name    |        label::english        |
| select_one mask-type | mask-used | Which mask type did you use? |
choices tab
| list name |   name   |       label::english       | media::image::english |
| mask-type | surgical | Normal surgical facemask   | Surgical.jpg          |
| mask-type | n95      | N95 respirators mask       | N95.jpg               |
settings tab (optional)
| default_language |
| english          |
masks.xlsx (9.7 KB)
Hey guys,
I am having a similar issue. I am able to loud images for both of my languages, however I am not able to show the associated label with each image. my appearance is set at compact-1 for the select-one question.
is the size of the image an issue?
Will O
Can you post the survey question (the line(s) from your survey and choices sheets) and images you are trying to use here? Feel free to change the words (leaving the strings the same number of characters) and just post the image pixel dimensions if the content is confidential.
That was very very helpful , many thanks for helping me in that
Abrar
Thanks a lot for your help , I have solved this
Abrar
Exactly my suggestion. The media::image column has to be on the choices list and not in the survey. The inconsistencies in the media column in the survey sheet contributed to it not working.
